confirmed these two works but LetsVPN block you for no reason even if you have paid…
Netflix no longer works for me for LetsVPN
If you try to use Disney or Prime with a VPN their systems will flag it and they won’t work. Neither brand allows VPN’a unlike Netflix or Apple TV +.
Obviously you need to use a VPN at all to access stuff beyond the great firewall so you’re in a bit of a corner.
What I thought was, because Apple TV+ allows VPN’s, if I access Disney through Apple TV+ maybe it would work. I don’t know if Apple TV+ is just a payment portal or maybe somehow Disney runs through it.
But hard to find a reliable proxy, now I turn back to search a reliable VPN again😣
There is probably a correlation between me not posting what I do and it lasting me this many years. Apologies, I won’t be talking about it. Big hint, it isn’t anything commercial. GLHF
lets vpn works very well,(i am in shanghai), pretty much no issues at all. i could not get mullvard to operate so it could be an issue on my end? i think its very slow/just doesnt work at times
Fair enough. I mostly connected to U.K. servers in China and U.K. no problem
I found let’s less good for streaming stuff tbh but worth a shot as you can get it on short term subscriptions
Thank you, that’s really helpful!
Hm. 5g in shenzhen shouldn’t be an issue…
It might just be a quirk of using the sim slot on the pixel 9 fold… But at least you have a workaround for it.
It doesn’t work like that. Try using a shadowsocks proxy, if you find a good provider it’ll work flawlessly.
Your searching in the wrong places. There are a bunch of reliable proxy providers.
I am going to Shanghai too, thanks for sharing
It’s weird because I got good reception in the subway but on shopping centres it was atrocious. Especially the bottom level where the restaurants all are.
I guess it must be some way they deal with 5g repeaters inside.
Fair enough. Just thought it was worth a shot.
I have stremio with real debrid now so that works.
Alright, glad you found a solution! Feel free to shoot me a dm if you need any help with bypassing the gfw.
Thank you. I may just do that one of these days.
