"Something went wrong while getting your SSO info" - error on login
Thanks alot, You just saved alot of my time.
i have struggled during weeks. you made my day!
It works! Thank you so much!
same here mate, worked, thanks a lot!
yep, OpenAI uses Auth0 for their authentication.
Excelente muchas gracias!
Didn’t seem to work for me. Just got shown an error page. I’m on Firefox. Using Proton VPN.
purtroppo non funziona, ho lo stesso problema ma se metto lo 0 mi da errore
Thank you! I have tried many methods, but yours is the one that works.
Thanks, it works again.
this it the right answer. Thank you.
how did you come up with this? brilliant.
WORKS. thank you so much
Thank you for your response. It was very helpful for the web version, but is there a way for me to log in using the Android app as well? Please help!
THAAAANKS! You saved my skin! OP, marry me! :slight_smile:
thank you! you are cool! since yesterday I couldn’t login and previous lifehack didn’t work. But yours is working fine!
I’m wondering why we have to do this to chatgpt, the don’t know about the problem (ironic)?
Lord…such a dumb bug
See the most upvoted comment here - I’ve tested it and it works. What a weird company.
Same issue on my end. It’s frustrating that OpenAI doesn’t support good security practices. I’m often on public WiFi and have to use VPN.
Still works, but had to clear cookies and changed VPN location three times before worked.
Thanks
