Will redeeming multiple keys with a VPN cause any issues for me?
I’m getting 3 6-Month Game pass core keys which I’m going to convert to GPU, I believe there are 6 3-months codes, will there be problems if I redeem all 6 in one sitting with a VPN? or should I spread the process out on a couple of days?
There won’t be any issues. This is how most of them stack the GPU
just bought Indian game pass core codes but was not able to redeem them in an European microsoft account. It keeps saying that these codes are not for my region. Have used NordVPN
A problem that ive had is that you won’t be able to redeem your microsoft rewards points because the use of a vpn
Depends which country your keys are for. some regions have a 13 month limit https://support.xbox.com/en-US/help/subscriptions-billing/manage-subscriptions/xbox-subscription-extension-limits otherwise if the codes are for a country that has 36 month limit you should be able to do it all at once
No, I have been doing it for 4 years and never once had an issue.
My GamePass Ultimate expires in 9 days. I plan to let it expire then do the GamePass Core codes. Are we still able to buy codes for India region and use a VPN to redeem them on our account?
Ghost VPN works well for Turkey, Nigeria, India. I just used it for 3yrs worth of 3 month codes for India. There is a free trial for Ghost and / or you can get money back by cancelling within 1 week or so
might need to try a different vpn, some people have reported success with surfshark or purevpn on the master thread
https://www.reddit.com/r/XboxGamePass/comments/sy2fne/game_pass_deals_conversion/
using a vpn is not going to change the country your account is based in. Not how that works
When you use Nkedvpn does it allow you to select India as the country to spoof your location from? Bc that’s what you’ll need. I use surfshark and it worked fine.
They’re Indian region, which thankfully isn’t one of the countries listed, but won’t my account get flagged for claiming so many keys from a different region?
Actually it is how it works. Certain keys like game keys and game pass core can be redeemed using a VPN even if your account region doesnt match they key
there are hunders of document cases of this working in the master thread https://www.reddit.com/r/XboxGamePass/comments/sy2fne/game_pass_deals_conversion/
but sometimes it doesnt work with every VPN
No, because you are still redeeming legitimate keys. People have been redeeming foreign gold/core and game keys for years without issues. there is a whole master thread where this has been discussed and confirming this Game Pass Deals & Conversion : r/XboxGamePass (reddit.com)
Although some people have had some issues redeeming foreign core, but that could just be a user or vpn issue
Do you recommend any particular vpns?
some people recenenly have reported success with purevpn or surfshark. Urban VPN is a free one, but they aren’t good for privacy. Using it to redeem keys is fine, but don’t use it if you are doing something illegal
i had trouble using argentina codes thru surfshark a few weeks ago, which was odd. usually works every time so thought they must have closed the loophole. but nope, hola worked fine (but it’s hola…)
Wonder if they are trying to block known VPNs. it’s like Netflix sometimes I can use a VPN to watch other regions and sometimes it detects that I am using a VPN and blocks it
i wondered this, but i think it might be more to do with it being a virtual server than anything. most websites would load as if i was in the u.s. they probably just need to get it up and working better i think
