in my opinion, it is one of the worst browsers out there, it may be handy and convenient but it’s the most unreliable browsers I have ever used.
using it for years… for the most part its my main browser but i also use firefox and edge depending on what im using it for
i got all the useless stuff disabled, my youtube works, my speed dials work so i dont have an issue currently*
GX, My Flow, Ad Block, VPN, Attractive UI, Stable.
I switched like 3 years ago and will continue to use it until I come across something that has a feature I “need” or I just like more, OR it seriously disappoints me in some way.
Works great for me, less Google than chrome
side bar, islands, ad blocker, AI, and doesn’t crash like chrome does.
Are you asking because you want a good reason to use it again? If you’re not, I don’t see a good reason to bother typing out an answer.
I only came into the thread, hoping somebody had a better suggestion
I’ve been using it for almost 20 years. I never had any issues until recently when they decided to add a frame and now I’m terrified of using the scroll bar because the window can change size and get frozen.
I still use it because I have everything here (bookmarks, passwords, etc.), I’m not too keen on moving everything to a new browser, but I will if this isn’t fixed soon.
Why is it unreliable? I was a chrome simp for a long time but now I use GX because it’s just as fast as chrome, and if both are even I’d rather use a browser that doesn’t have questionable privacy policies.
I don’t, I dropped this crap for Firefox.
It is the Only browser for the Nintendo DSi
Why wouldnt I? It works fine and the usage is decent, too. Wdym unreliable?
Nope, switched to Arc
I don’t. I’ve used Firefox the last few months and it’s the best one hads down. I don’t know why this subs posts keep getting recommended to me
I haven’t for years and idk why I’m still subbed here.
Free built-in vpn to open wowhead in my country - for everything else Chrome with couple of plugins
IT’S A BUGGY BROWSER FOR SURE, I JUST LIKE THAT I CAN HAVE MY TWITTER AND WHATS APP IN THE SIDE PANEL
I use more then 20 years,
literally what is wrong with opera
Yes, I still use Opera.
