What’s the best way to make a feature request? PIA WireGuard for VPN Client
PIA doesn’t offer WireGuard profiles, but I noticed that somehow the gl.inet app allows setting up their routers with a PIA WireGuard config. Not sure how it’s doing that, but would love if Firewalla app could do the same (since PIA won’t provide it for some reason).
Change from PIA, they are way behind in supporting profiles for WireGuard and was asked on their forums over 12 months ago
I’m sure this post itself is an informal feature request, they’ll see it
See this thread https://www.reddit.com/r/firewalla/comments/pj1fw6/pia_config_files_for_wireguard_vpn_client_on_fwb/?utm_source=share&utm_medium=web2x&context=3
Any Recommendations? I don’t think anyone beats their pricing, makes it hard to switch.
Thanks for sharing that. But similar to what gl.inet did, would love for Firewalla to bake that into the app to make it even easier :slight_smile:
Keepsolid VPNUnlimited. One time pay. Company is Ukrainian. I switched from PIA to VPNUnlimited years ago and they are very good.
I really really like Surfshark they are one of the better reviewed VPNs they also just started offering static IPs. I’m using it with wiregaurd on my firewalla.
There is no way we are going to support this, if the provider decide to hide the profile …
I have a few gl.inet devices, great stuff, gl.inet does it in their cloud UI, not on the device. They probably run the same scripts to get the WG keys from PIA. Just run these scripts and get the key. Or! Get the pia keys from the GLi router and use them. Just use the keys on 1 device at a time.
My PIA WG connection has been active for months now. Just have to get the keys once. They only expire if you lose your connection over x amount of hours. If you have a good connection, the keys don’t expire.
Appreciate the link, but not seeing anything that tells me which provide WireGuard profiles to customers. Perhaps I overlooked it as I checked it out on my phone.
