Watchguard Firebox t35 VPN licenses question
Does the Watchguard T35 require you to purchase VPN licenses for the SSL Client? I know the unit supports upto 25 VPN connections and it appears that the IPSEC client is license based but are the IKE2 and SSL VPN Client options also license based?
No, the 25 licenses come included with the Firebox, nothing else needs to be purchased.
You can use the built in Windows 10 VPN client. There is a setup file you can download that will set it up for including the certificate install for IKEv2. Then you can modify it for dialup connection so it will be available per login. Just got done setting this up two days ago.
If you go to the feature key section it show’s you how many users for each VPN type you get.
You should get 25 users per VPN type listed there… the only thing I’m not certain of is if you have 25 SSL users idk if you can then use something like IKE mobile vpn to increase to 50… I think it’s 25 vpn users total but I may be wrong about how that adds up…
Yea that I figured. I just wasn’t sure of the client licenses only applied to the IPSec client or if the SSL client was also licensed based.
