Vpn with fire stick?
Currently have a 1 gig up and down fiber connection at the house. I have a few 3 year old PC’s laying around and would like to create a VPN that I can use with a fire stick at my summer house in another state. What is a simplest / most cost effective way to make this happen please?
Used raspberry Pi 1b, pivpn running wireguard. Cheap to set up, cheap to run.
Okay so if I were to get a “TP-Link Tri-Band BE19000 WiFi 7 Router” in house 1 and then I bought a “GL.iNet GL-AXT1800 (Slate AX) Pocket-Sized Wi-Fi 6 Gigabit Travel Router” And set it up in house 2 could I use that to tunnel into my home network before exiting to the public internet using the TP-link router… TP-Link says it has the option to have VPN clients and server supported
If I’m incorrect please point me in the right direction.
Thanks
Are you asking about setting up a private VPN at home? If you are trying to get around geo restrictions why not just put a commercial VPN app directly on your firestick?
Because of certain restrictions with some paid viewing apps it would be more beneficial to have all traffic routed to my house before hitting the paid applications server. For example Hulu with live TV. Unless you have a better idea in which case I’m listening
I have a similar setup with similar motivation, but I started earlier so my setup is getting old.
It seems all Fire TV Stick solutions for self-hosted VPNs require sideloading Android apps. There are some frustrations because of that, but let’s assume you’re willing to put up with that.
I have a Softether server hosted on a Raspberry Pi. It works great, but compared to a setup-and-forget Tailscale host, it’s high maintenance.
My router has built-in VPN. This would be the easiest to set up. I also don’t trust the router to handle extra tasks. If it gives up and needs a physical reset, I’m done. So no thanks.
A recent storm cut the power to the house for nearly a day. The media server on my laptop ran out of battery and shut down. Unlike a desktop with “restart after power outage” in the BIOS, cheap laptops like mine don’t have that. So a laptop is quiet, low power, and has basic backup power. It won’t self-restart after an extended outage.
A desktop PC is a power hog and noisy. I don’t really want it in my house, unless I have a dedicated server room or at least a cabinet.
So I came to the conclusion that a Raspberry Pi is my ideal host. It seems to handle full HD streaming no problem, so the tiny ARM CPU does its job. I did notice the 3D printed case was warped after a summer, so heat and ventilation is an issue. But it’s quiet and low power. It auto-restarts after a power outage.
My plan is to migrate to Tailscale this summer. It’s what I’d do if I were setting up a new host now. Otherwise, Softether works great too. It’s not legacy. It’s just way too feature-rich for your use and my use, meaning you need to be a part-time admin.
The PC doesn’t bother me too much. But I’m guessing an I-5 processor and 8 gigs of RAM is overkill? I guess I’m going to have to look into tail scale and figure out how that works ASAP. Thanks for pointing me in the right direction
I know someone (in the comments section) used this guide for Tailscale with a Firestick and it worked.
And the cost for the hardware is typically under £15 if you buy used.
How any tutorials on this?
Think this is the one I used
Ty will check out. How much is it running you monthly?
Pennies on electricity seeing it runs on usb
