VPN option in settings
Hi. So I was just browsing through the settings on my iPhone 11 and I noticed that we have a setting for VPN, just below the option for personal hotspot. It just has that on/off switch.
I couldn’t change any VPN settings or anything, but I could turn it on or off. Could someone tell me what this does?
I have multiple VPN profiles. Switching between them using this interface is faster than using the dedicated apps.
Thanks for this. I’ll check it out.
Ohh okay, thanks for your response.
If you decide to use one make sure you do your research, and if you start to have trouble with connectivity turn off or even uninstall the VPN as part of your initial trouble shooting. If you call for assistance make sure you mention the VPN! :slight_smile:
Oh okay. I started using TunnelBear, the free version and it’s quite good. Now I’m planning on testing Proton.
Thanks for your support.
