RESOLVED:
I finally figured out the issue. For whatever reason User group for XAUTH users setting in Group VPN policy was the cause. It was set to Sonicwall Administrators which its always been and its never caused a problem with GVC. But I changed it to Trusted Users and suddenly GVC started working again. Doesn’t make sense that it suddenly became an issue but at least it resolved the problem
With GVC they get prompted with the username and password dialogue box but when they enter it it fails. This happens from multiple locations. Below I have pasted the log file of the GVC client. Clearly the problem is not a user credential issue since it works from Mobile Connect. It was working fine last week. Any suggestions?Connection IP in logs has been hidden for security reasons obviously---------------------------
2023/09/18 12:12:41:982 Information The connection “*.*.*.*” has been enabled.2023/09/18 12:12:42:633 Information *.*.*.* Starting ISAKMP phase 1 negotiation.2023/09/18 12:12:42:679 Information *.*.*.* Starting aggressive mode phase 1 exchange.2023/09/18 12:12:42:679 Information *.*.*.* NAT Detected: Local host is behind a NAT device.2023/09/18 12:12:42:679 Information *.*.*.* The SA lifetime for phase 1 is 28800 seconds.2023/09/18 12:12:42:679 Information *.*.*.* Phase 1 has completed.2023/09/18 12:12:42:722 Information *.*.*.* Received XAuth request.2023/09/18 12:12:42:722 Information *.*.*.* XAuth has requested a username but one has not yet been specified.2023/09/18 12:12:42:722 Information *.*.*.* Sending phase 1 delete.2023/09/18 12:12:42:722 Information *.*.*.* User authentication information is needed to complete the connection.2023/09/18 12:12:42:754 Information An incoming ISAKMP packet from *.*.*.* was ignored.2023/09/18 12:12:54:567 Information *.*.*.* Starting ISAKMP phase 1 negotiation.2023/09/18 12:12:54:597 Information *.*.*.* Starting aggressive mode phase 1 exchange.2023/09/18 12:12:54:597 Information *.*.*.* NAT Detected: Local host is behind a NAT device.2023/09/18 12:12:54:597 Information *.*.*.* The SA lifetime for phase 1 is 28800 seconds.2023/09/18 12:12:54:597 Information *.*.*.* Phase 1 has completed.2023/09/18 12:12:54:632 Information *.*.*.* Received XAuth request.2023/09/18 12:12:54:632 Information *.*.*.* Sending XAuth reply.2023/09/18 12:12:54:632 Information *.*.*.* Received initial contact notify.2023/09/18 12:12:54:647 Information *.*.*.* Received XAuth status.2023/09/18 12:12:54:647 Information *.*.*.* Sending XAuth acknowledgement.2023/09/18 12:12:54:647 Warning *.*.*.* XAuth failed. (null)2023/09/18 12:12:54:647 Warning *.*.*.* User authentication has failed.2023/09/18 12:12:54:681 Information An incoming ISAKMP packet from *.*.*.* was ignored.2023/09/18 12:16:34:859 Warning *.*.*.* The username/password dialog box was cancelled by the user. The connection will be disabled.
