Greetings all,
Do you have any idea, how to make automation which disables my VPN connection when I reach my home network. It’s pretty annoying I have to manually disable OpenVPN on my iPhone, every time i come home. Otherwise i have issues with connectivity.
Thanks in advance!
I use Passepartout instead of the official OpenVPN client. It allows you to add trusted networks where the VPN connection will be automatically disabled.
Passepartout on the AppStore
You can’t run an automation automatically when connecting to Wifi.
Ah! It’s
“Open source
Source code is available on GitHub under the GPLv3.”
That’s great! I’ll try it today
Sounds great. Is it trustworthy? I mean, how do you trust all your traffic to an app?
Yes, it’s a great App. There’s also a subreddit for it.
Been using it for over a year now and haven’t even thought about going back to the official app.
