all of these used to, but i cant use any of them with my school wifi. any way to get around this?
One I found to work well to circumvent VPN blocks has been Windscribe with Stealth protocol on port 443 with Circumvent Censorship on. It’s worked even when IKEv2 and Wireguard don’t work.
Try and use a different DNS like cloud flares 1.1.1.1 and see if that helps
Sorry idk what that means can u explain it to me like I’m 5 thanks!!
this worked i appreciate u so much tytytyty
edit stealth & 443 dont work but ikep2 and circuvent censorship does on this network
IKEv2, Stealth, and Wireguard are three different ways to connect to a VPN. Usually you can select between a few different options in each provider’s VPN app.
Using Stealth on Windscribe VPN, and then turning “Circumvent Censorship” (a toggle on Windscribe’s app) on has worked well for me when VPNs are being blocked
