Trying to setup VPN for GigaSpire BLAST
I’m trying to set up my SurfShark VPN on my Calix GigaSpire Blast, but I’m struggling to do so. Everything I find online says there should be a VPN Client tab under my router’s configuration panel, and if there is no such tab (there isn’t for me), then it seems purchasing a firewall is the only option. Is there any way around this?
Any help would be much appreciated. Thanks!
EXOS does not have a built in vpn client.
Have you found a solution? I am currently in the same situation and could use some help.
Unfortunately not. I don’t think the GigaSpire supports VPNs :frowning:
Was looking up the same thing today for Nord. Damn…
