SSL VPN Rule for Multiwan
This is the dumbest thing to be stumping me, but I am having an issue determining what policy I should make compared to the default policy. The watchguard I am working with is cloud managed, and I need to enable SSL VPN. However, that’s taking over an answering before the other SNAT forwards we have. What policy will limit the firebox so it is only answering on a specific public IP for SSL VPN?
Ok, I got it and I am going to leave here for others. If you enable SSL VPN, the watchguard will answer on all public IP’s with the default policy, which is from: any-external to: firebox. If you need to limit answering to a specific public IP, disable the default policy (or core policy in watchguard cloud). Then create a new policy for traffic type SSL-VPN. Source should be any external, destination should be the public IP you want to answer on. Of course it needs to be an IP that is programmed into one of your wan interfaces either as a primary or secondary network.
