afaik “stealth” tries to mask that you’re using a VPN
Thanks for all answers.
I have gone through the various VPN profiles I have set up.
Stealth for all secure core connections.
Stealth for my PSP connections.
WireGuard (UDP) for the rest.
Of course I will keep on fiddling with it, but that will do for now for routine usage.
Thank you. A good rundown that answers most of my question, including some I didn’t know I had.
Still doesn’t explain how ‘Smart’ decides.
Again thank you.
I’m getting this implies I don’t need it if I’m on a computer that I physically control and also physically control the router?
