Proxy and Wireguard Config?
my current VPN is about to expire, I am thinking of getting Surfshark is it has great speed and country selection.
I have 2 requirements, I wanted to clarify if Surfshark provides them.
  1. Proxy, any kind https or socks5 and if so then do they provide an address list?
  2. Wireguard config file which I can use directly with Wireguard app
Hi there, thank you for reaching out. It’s great to hear you are considering Surfshark, and I’m here to address your questions.
  1. We do indeed the HTTPS protocol. You can use it by setting up and connecting via the Surfshark browser extension. You can find the full list of our servers here: https://surfshark.com/servers
  2. You will be able to download WireGuard configuration files from our website, and use them to connect manually directly through the WireGuard application. After purchasing the subscription, you can download these files here: https://my.surfshark.com/vpn/manual-setup/main/wireguard
Thanks for the quick response and clarification. One last thing, does SurfShark provide Dedicated IP with port forwarding
Yes, but no port forward.
