Hi,
I am on a paid Plan and protonVPN extension is disconnecting very often today. I have tried servers in different locations. Didn’t help. I see you are having outage issues: Proton Services Status - Partial outage on ProtonVPN servers in a few countries. When are you going to fix it?
I need your VPN for work, please provide a list of locations/servers that are not affected and which are working stable now. At least for today and tomorrow.
What servers have you experienced issues with?
Have you tried changing connection protocols: https://protonvpn.com/support/how-to-change-vpn-protocols/ ?
What you’re experiencing is likely a local issue, since you’ll likely see a wrench icon (maintenance) for the servers that are impacted by this outage.
If you continue experiencing connection issues, please contact us through the ‘Report an issue’ option in the app menu, and send us the error logs, so our technical support team can investigate further and help you troubleshoot accordingly.
