Pros of using 1.1.1.1 app over DNS network settings?
I was wondering if there are any real benefits to using the 1.1.1.1 app over just setting 1.1.1.1 DNS directly in my network settings. Since the app takes up resources, needs updates, and has additional features I don’t really use (like WARP), I’m curious if it’s worth it. I only use the app for the 1.1.1.1 DNS, not for WARP or anything else.
A while ago, I thought the app helped lower my ping in games, but now I’m wondering if that was just a coincidence. Can anyone clarify if there are any true pros to sticking with the app instead of just configuring DNS manually? Thanks!"
If you’re on iOS, there’s no way to configure DNS globally without an app like 1.1.1.1.
If you’re on iOS there are system profiles that are available from community forums for Cloudflare. I’d like to just make the case for Quad9, a very good, albeit smaller, but malware blocking and very privacy preserving resolver. They offer official ios profiles on their website.
What do you use for the secondary IPV4 and both IPV6 addresses?
The app is useful just because mobile phones do not have option to configure DNS servers for dynamic IP like you have with desktop OS. Other than that, just configuring the DNS on your router is fine.
That app has a few perks, like automatic DNS switching and built-in security features, but if you’re only using the DNS and not WARP, manually setting it up might save you resources. The app updates automatically, which is handy for security, but it might not actually lower your ping. If you’re just looking for basic DNS, doing it manually should work just as well without the app.
If you’re on android use private DNS and one.one.one.one
There are some device management profiles people have made for cloudflare, to set this at the system-wide level for most everything. I believe the app store and icloud private relay always use system DNS
Oh, cool I didn’t know about that, thx for the response
. . . that left the States and relocated to Switzerland to ensure their ability to provide us with safe and secure services. I’ve been using them before they moved.
If I’m using manual settings, I configure the DNS as this:
  • IPv4: 1.1.1.1 and 1.0.0.1
  • IPv6: 2606:4700:4700::1111 and 2606:4700:4700::1001
However, when I use the app, it automatically switches to the DNS servers assigned by the app, overriding the manual settings.
Thx, I’ll search on how to setup dns on my router
Yeah you can use it and another is
I forgot about that. Management profiles can install custom DNS settings, but I think it’s only DoH and DoT.
