PIA and "Multi-Hop" Proxy
Hi! I’m running Windows 10 with the latest version of PIA. If you need additional information please let me know.
I have PIA connected to a VPN server in the US and also I enabled a US proxy in the “Multi-Hop / VIA Shadow Socks” setting that claims to “hide the fact that I’m using a VPN.” Yet when I go to https://whoer.com/ it shows the VPN address and says “Proxy: NO” Every site and test I ran shows the VPN address and NO proxy. Help with this is appreciated. Thanks!
Shadow socks proxy hides the fact you’re using a VPN from your ISP or any other intermediaries between your system and the VPN endpoint. The actual requests you make of course still come from the VPN exit-node.
It’s primarily useful for restrictive firewalls and censorship countries.
So if I sign up for a discussion forum group site using the VPN and the proxy enabled the site I sign up with won’t know I’m using a VPN? However if I have the VPN and proxy enabled and I personally check my IP it will show the VPN address to me though and not the proxy? For anyone else they don’t see the VPN they will see only a proxy address? Thanks!
You don´t really get anything, everybody you visit is going to see your VPN IP.
Only your connection to the VPN server is hidden. Requests you make (like to websites, as in your case) still come from the VPN exit node, so it’s possible they may figure it out, but it’s non-trivial to find that information out; so i wouldn’t worry too much. They’d likely need a list of VPN ips.
Thanks! So at the end of the day using the VPN in conjunction with the proxy only prevents my ISP from seeing I’m using a VPN? My ISP however will see the proxy IP? I’m trying to learn as much as I can. Thanks again!
ISP or any intermediary - like work firewalls, libraries, schools etc.
