The PIA application (its agent to be fair) disable icloud private relay. I know a vpn is better but still on iOs it works fine with both on. Plus, some year ago there was a page on the PIA website with tutorial to setup PIA without the app, using the built in vpn client under system preferences/ network. I cant find the page anymore is it still possible? Thanks
Is this ever going to get fixed ? Other VPNs iCloud private relay works with the vpn why not PIA
FYI – This is still a problem, as far as I can tell, with macOS Ventura 13.1 and PIA v3.3.1 (build 06924).
Still the case as of MARCH 2024, so it’s not possible to use PIA (split-tunnel in my case) and iCloud Private Relay at the same time?
I confirm this issue still exists with macOS Sonoma 14.4.1
PIA Support told me to contact Apple Support because PIA is not designed to block anything.
I am not convinced by this answer, honestly.
Simply installing the PIA app makes iCloud Private Relay become unavailable.
Still happening on Sequoia 15.2
Try searching for this: PIA Manual Setup on MacOS. This will help. I can’t test it since PIA’s website is blocked here by the ISP
Is this being worked on by PIA/Apple? Should we expect a resolution to this incompatibility? What is the official word on this if any?
I was unable to resolve this, so I switched to Mulvad.
Has someone maybe tested it with macOS Ventura beta? Perhaps private relay is out of beta there and working with PIA?
PIA and iCloud Private Relay are still not compatible.
I came looking for answers because the Mail.app client would not automatically Load remote content because of my network settings. But I wanted to maintain privacy, not just disable the privacy options. To get images loading automatically in my email, while maintaining privacy, I needed iCloud Private Relay to work. (Or use a VPN full-time, but I don’t care to do that either.)
I had PIA client installed on my M1 Mac.
MacOS Sonoma 14.0.
PIA Client 3.5 (build 07703).
iCloud Private Relay was reporting incompatible system settings, and as soon as I uninstalled the PIA Client, Private Relay started right up. Something about the “helper tool” installed by PIA disables Private Relay.
Instead of using the PIA client, I was able to connect to PIA servers using the OpenVPN Connect client. You can get OVPN configurations at the very bottom of the PIA → Account → Downloads page - either configure a specific set of settings, or download a zip of the recommended default configurations.
Note that OpenVPN Connect complains that the OVPN profile is “Missing external certificate”, but you can “Continue” past that warning with no consequence.
Hope this helps someone.
The problem still exists with MacOS 13.6
I contacted PIA support to report this but they haven’t replied to me yet. IF/when they reply, I will let you know.
Cheers
Original Content erased using Ereddicator. Want to wipe your own Reddit history? Please see GitHub - Jelly-Pudding/ereddicator: A Python script to delete all comments and posts of a Reddit user for instructions.
Thanks. I found this video https://youtu.be/jtKWv4mUAek it’s more or less what I remember, but it’s 5y old now. I’m going to test it when i get home.
There’s no trace of it on the pia website anymore I searched for 1 hour yesterday.
I bought a 3y plan 4 months ago, i didn’t have Monterey back then coz my mac was unable to upgrade so i did’t know about this. What a cringe.
Hi, nope, none. I ended up disabling private relay on mac os since it’s still in beta but im considering another vpn. The page with the manual setup is gone.
FWIW, PIA v3.3.1 and macOS 13.0.1 still experience this issue. Also, it’s the same underlying cause as the incompatibility with the Mail Privacy Protection. https://www.reddit.com/r/PrivateInternetAccess/comments/qioeyc/pia_monterey_mail_privacy_protection/
I could understand saying “well you don’t need redundant VPNs for Safari” but this Mail feature is useful on its own merits, and because it uses the same relay backbone (albeit in an entirely different way) PIA merely being installed still breaks it. Really a shame. It’s been long enough that this feature’s been out, we should have seen a fix by now.
And a new beta version 3.4.0 is out which natively supports Apple Silicon. https://www.reddit.com/r/PrivateInternetAccess/comments/wrfrcq/pia_desktop_v340_beta_released_today_with_native/
Maybe Private Relay works with that version?
Thanks for sharing this - I’m in the same boat as you with the Mail.app
I am in the middle of mine. Mullvad is more expensive, but I guess you get what you pay for.
