[Others]For everyone whose Spotify doesn't work try another account it worked for me
maybe we got banned or something
  1. Restart phone 2. Without opening Spotify, u go to settings and clear all data for Spotify 3. Download a VPN, used “VPN Super Unlimited Proxy” from the play store
  2. Set country to USA 5. Open web browser and go to Spotify account settings 6. Change region to USA
    7.Open Spotify
  3. If it works you can disable the vpn Done.
I don’t believe that we got banned because I am able to log into my account just fine from my pc (cracked). Maybe they had a bad day and decided to hunt down all cracked users?
It seems to be region-specific. For some it started working again after they used VPN and switched their account to another location.
I had to update my password and it works
Legend! Worked for me!
yea idk its so weird
What locations seem to be working
Yep worked for me I even switched the VPN off after and it still worked
It works, I just did that and I’m linked through Facebook.
Had to change email on Spotify profile first before activating the VPN, then o turned on the VPN and changed region no problem.
But I still login through Facebook on the app.
Some Portuguese users have switched their region to Spain and it seems to work for them.
I can confirm this works, I’m from Portugal, changed the region to Spain, turned off the VPN and it still works. Thanks :sign_of_the_horns:
I’m from Spain and I’ve had the same issues, so I think just the act of switching it is what’s making it work.
