Options for developpers menu fails after Android TV R12 upgrade
The Android TV release 12 update worked for me on my Mi Box 4 but I notice one issue : after activation the options for developpers menu, I cannot open it at all. And then, I cannot des-activate it neither.
Did someone face the same issue ?
Thanks
Yes this is only one of the many problems (number 7 is developer options no longer working) that I encountered with this crappy update on my MiBox and reason why they pulled it now. Many have reported that doing a Factory Reset (this reset will keep you on Android TV version 12) fixes most of these issues below in the new Android TV version 12 that I found happening on my MiBox4 (MiBox S).
  1. Can’t read SD card (detects the USB thumb drive in System Settings/Storage but cannot read the files in it)
  2. Kodi no longer opens (blank screen)
  3. X-Plore file manager no longer opens (blank screen)
  4. MxPlayer no longer opens (blank screen)
  5. SMB network (network connection on VLC no longer works, it can read the network but not the files in it)
  6. both my Avast SecureLine VPN and HMA VPN won’t open (blank screen)
  7. No longer have access to Developer Option in Settings (you click on it and it exits) although I am setup to have developer options
  8. My Bluetooth speaker does work on Android 12 but sound crackles/mutes at times every couple of minutes for a 1/2 a second or so and I tested this on a few different aps (I also cleared the cache in the Bluetooth system app and same thing happens)
  9. When I turn off the MiBox and turn it back on a few hours later, instead of starting up normally, it starts with the MI sign just like when you did a reboot and then you get the Android TV animation screen and then it starts up.
  10. Remote on Google TV app on cel phone no longer works and you cannot control your MiBox using the Google TV app anymore as mentioned in this video https://www.youtube.com/watch?v=zVY2WMJ2SHI since this update to Android TV version 12
  11. Google Play Store app crashes at times (black screen won’t open) or crashes when opened at times and I have to reboot for it to work properly again
  12. Whenever you either use the Google assistant or speak in the Gboard (anything that requires you to use the microphone) there is now a green little icon that appears on top right but when you stop speaking sometimes a little green circular dot will remain on top right of your screen that you cannot remove unless you reboot.
I suggest everyone email their support by using link below:
Maybe try one of those ‘hidden settings’ apps to see if that will open the developers options for you. It’s how I have to get to battery optimisation on a couple of my devices.
Any confirmation that a factory reset will fix the developer options menu? I just updated from Android 9 to 12 and I’m facing this issue… although Kodi, MX player and X-plore works fine for me :slight_smile:
No idea, I have too many things setup so I am not factory resetting it and I decided I can live without the developer options menu for now.
I’m on the same situation hahaha let’s hope someone answers…
