The problem: I understand there is a lot of hatred against Nord in this community but it has worked perfectly well for me over the past 5 years. Then about 2 weeks ago I have been stuck on downloading meta data with 0 peers and 0 seeders for all. I have 0 Nodes. I have Microsoft 11
Setup: I have used all the setup and settings that have been listed at NordVPN proxy setup for qBittorrent – Live Chat, VPN Setup, Troubleshooting | NordVPN Customer Support. These settings allowed me sufficient download speeds with zero leaks.
Binding: Yes, I have Nordlynx selected to bind me to my VPN along with kill switch on Nord as well as the program killswitch for Qbittorent. I understand the questionable behavior of kill switches so that is why I bind
Version: I am using Bittorrent v4.6.5. I have deleted the program 4 different times. Twice keeping the settings on reload and twice without.
Firewall: Both public and private permissions selected.
Trackers: I have copied and pasted trackers from another reddit link. This link I cannot find. I have “reannounce all trackers when I change routers” selected
New Socks5 Links: I utilized a few new Socks5 links from here https://www.reddit.com/r/nordvpn/comments/16soaf6/updated\_nordvpn\_socks5\_proxy\_list/. This worked for all of 30 minutes after I confirmed it was working through ipleak. Then everything stopped.
I am all out of ideas so if this community has any solutions that would be helpful. If you need any other info on which settings I have selected just ask and I will try to provide. Thank you in advance.
