Need help with mudfish VPN
Hey community, I recently picked up ESO but I’m facing terrible latency (ping) from where I play which is Singapore and it ranges from about 280 - 330+. I’m wondering if mudfish will help to lower the latency. Sometimes I can’t even bar swap properly because of the delay. I hope someone can let me know the configuration to set up the routing. Thanks.
The best you’ll get is 250 pretty much. That’s as low as vpns can get me anyway
A VPN will increase latency… You’re just going to add a middleman when your console sends/receives a signal.
mate i play in singapore too. i doubt VPN will help much. while the latency numbers may be smaller, the latency displayed in game will represent “latency between server and vpn net” instead of “latency between server and your computer”.
Can you tell me how to configure the set up? The routing and the nodes…? I don’t quite understand it. I hope to achieve 250 ping as well… As much as I can. It’s going crazy now.
Your Destination server should be also US central right? The nodes you leave it on auto selection I assume?
Oh goodness my latency ping went up to 450 with the mudfish activated lol gg…
Yeah I just bought the cheapest credits which is like SGD $4+ it’s on auto configuration right now and stuck at 10%
I finally got it to look like yours but hmm… the in game ping still show above 250. Maybe it’s a gimmick?
