So I know there’s a limit of 2 devices on LetsVPN. I’m planning on installing LetsVPN on more than 2 devices, but I have no need to use LetsVPN on more than 2 devices at the same time. How do I change the devices it’s being used on? Is it automatic?
In the app you can see which devices are connected to Let’s VPN. You need to use the device you want to keep using to remove the device you no longer want to use. After that’s done you’ll have a free spot and can add your other device.
Eg. Phone and Laptop are granted access to Let’s VPN, but you wanna use a Tablet instead of the Laptop.
You need to use the Phone to remove the Laptop’s access and then you can add the Tablet after that.
They have a support article which has screenshots and whatnot about it: https://d3jb1hiazbhf2r.cloudfront.net/letsvpn-world/en/articles/2925976-use-one-subscription-on-multiple-devices
Just manage ‘switching’ between devices from your major device (so you can log out from PC on your phone etc.).
