Monster Hunter Now soft launches today in some countries like Canada, Hong Kong, Singapore or Sweden. (Source: mh_now_en official Instagram)
I tried to play it today via a Swedish VPN, and it worked perfectly during my 1h30~ of gameplay
It’s so fun and I can’t wait to meet new Hunters outside for the grind!
Not OP but for those wondering I was able to get the APK from APK Mirror while using my Mullvad VPN. Game doesn’t work if the VPN is off (You get a message on the loading screen then logs you out) but works as intended otherwise.
There has to be some free Canadian VPN or whatever other country is available on.
I created a Swedish google account to download the APK directly from the Play Store, but I think you could just change your country and it can work? I just wanted to be sure it would work.
For the VPN I use Tunnelbear, I think it’s very convenient, free, and quick to use.
Tunnelbear helps for the download, but there seems to be a limit on how much I can assess the VPN to Canada, unless I pay a premium. But turbo VPN I think offers an alternative that is free but with adds unfortunately.
