Monitor incoming vpn connection
Hi all,
is there a way to monitor incoming connections to the unraid vpn server? In the dashboard I only see how much time has passed since the last connection and the data transferred, I would like to have a log and some more data if it were possible…
thanks in advance!
Wireguard does that? I can see total traffic. Or is that not what you’re after?
yes, wireguard shows total traffic, but i dont see if a vpn connection is in use or not… at the moment it only shows the time elapsed since the last handshake, but it doesnt indicate if there is someone connected or not…
