I recently switched from AirVPN to Proton at the advice of this sub and have been happy with the down speeds. However, since the switch I feel that I might not be as connectable. My seeding speeds seem low, I allow uploads to 10Mb/s and on public tracker torrents for same day episodes I’m not seeing over 300kb/s. Yesterday when watching it I was connected to 12 out of 83 peers and only uploading at 64kb/s. I know there are many variables with this but I’m running to a close server, with about half load, with wireguard protocol. I have my port forwarded within qbit. Am I missing some piece config or is there any additional testing I can do to see about opening things up a bit more?
I mean you can do a speed test but you’ll only upload as much as they ask to get from you. I reach peak speeds port forwarded rarely, but it happens.
Interesting
I’m experiencing the same thing only I switched from proton to air vpn and now experiencing slow speeds
If in case you need VPN I offer few VPNs for cheap price
ExpressVPN- €2.50 for a month. Account is private, it means you can login into unlimited devices and can stay connected upto 8 devices at the same time
Surfshark- €2.50 per month, or if you go for 1 year or 6 months, it will be even cheaper price
Nord VPN- €2.50 per month or even cheaper when you go for 6 months, 1 year or 2 years.
FYI, ExpressVPN has fastest and stable servers.
if interested, DM me
Thanks for your reply on this. I usually use Ipleak for this same sort of detection and when I add their magnet link to Qbit it shows the port I have forwarded in Qbit. However when you go to your website it’s not showing the port open. Also interesting is that the in wireguard the last segment of my ip is .65 yet on both websites it’s showing as .69. Not sure if this could causes issues or not? So far I haven’t gotten a DMCA and definitely am reachable to some degree so I’m thinking everything is set up correct?
