and If so, anyone want to play?
idk how would you play multiplayer campaign, But I’m in for sure
Chat GPT says “Yes, you can use a VPN (Virtual Private Network) to achieve this. A VPN can create a secure connection between your two networks over the internet, making it seem like you are on the same local network. You could use software like Hamachi, ZeroTier, or Radmin VPN for this purpose. These services are designed to create a virtual LAN, allowing you to play LAN games together even when you’re not physically close.”
You Can use Hamachi it allow you to create a vpn so you Can Host a local server and play over long distance
Yes there is, you need a mod for that. I took a few screenshots on how to do that for a few friends.
I’m in for multiplayer coop campaign, what timezone are you in?
VPN take time and skill to set up usually, I don’t know if there are easy solutions to it but I think there are.
It’s not a vpn in the common sense (like nordvpn). A vpn literally means a virtual private network, meaning it simulates you being on one LAN.
If you are on mobile I’d recommend Tailscale as it’s super easy to set up.
I’m in east USA (probably the Chicago timezone), and I’ll check it out.
what’s your username and timezone so we can set up a time to play?
My username is irrelevant but same as here. I can play between 7am and 3pm UTC
okie dokie, we can play tomorrow at 3 pm, reply when you are ready to play.
I’m on summer break and stuff so I can play anytime.
we can play anytime between 7 and 3, just let me know when you are ready to play
let’s start at 8am UTC, which is 1h12 from now if i’m not mistaken
we might not be in the same timezone, or you may be mistaken because it’s 1:50 AM for me
yeah, 11:00 AM for me is 4 PM utc
my bad, est usa is 5 hrs behind utc
so it’s the middle of the night for you, my bad, didn’t think it through… if you’re up, host and i’ll join
yeah, I can send the code in a sec
CLaJqdxdMMjsomPWBuwsmabVCIbkGByVOGfpVZKqBVeCJU#n3.xpdustry.com:7025
