Is there a mod?
Is there a modded apk of the game that allows you to have infinite gems but that allows you to keep your progress? I want gems but I don’t want to lose what I’ve achieved
Watch ads you’ll be supporting the devs so they can put more contents out and you won’t spend a dime
Broski, just watch ads man, that’s just a super easy way to get gems. Do this for 10mins once in a while when you’re doing something else, and you’ll likely get all the gems you need
And after like 3-4 you start getting the puzzle ads which take like 5 seconds.
There are mods but they are very old versions and not fun to play. Also nome of them won’t let you keep your progress on the leader board and they will destroy your previous records
I just stopped getting ads entirety.
Use a VPN on different locations. Germany and USA almost always have ads
