Is it normal to get blocked using dedicated IP?
I got PIA after hearing good things, but I found I was getting blocked on some websites/services using the standard servers. So I thought if I got a dedicated IP, it would be less likely to be blocked. This is not the case, I am still blocked on the same things. I contacted support and eventually they gave me a new key, and the issue still persists with the same services blocking me.
So I am wondering, have I just made the wrong assumption about what a dedicated IP is for? Even though their dedicated IP page specifically states “Avoid blocklists” and “It can also help you avoid potential IP bans caused by other VPN users, as well as frustration with services that block known VPN IP addresses.”
Edit: I dediced to turn off the dedicated IP for fun and I am not blocked on the services I was previously blocked on anymore… Does anyone know why this might be?
Confirm what your actual IP address is when dedicated is on / off with a site like whatsmyip.org just to make sure things are set up the way you think they are.
It *can* but it might not. If the IP address was previously flagged by whatever list a site uses, its reputation might take some time to recover, if it does recover at all.
The whole subnet that the IP address belongs to might be flagged, depending on how much unusual traffic comes from it.
If there’s suspicious activity coming from your machines, it’s possible that the dedicated IP address’s reputation is still being hit.
Try giving it some time and doing normal human internet stuff with dedicated IP on.
Dedicated IPs can often still be identified as being owned by a VPN company. If you’re not concerned with anonymity, you could try setting up your own VPN on a digital ocean droplet.
Possibly the VPN IP you were assigned was previously used by a spammer or a bot. I’ve experienced having my VPN IP blocked. Also, some block any VPN.
Yes. PIA IPs are pretty much barred across the board by most major websites you’ll use on a daily basis.
Even trying to run a google search with a PIA turned on results in being forced to complete 1-2 capchas to see the search results, every time.
PIA was supposed to make things easier, but I have spent far, far too much time fucking about trying to work with their shitty account management.
I have PIA bought and paid for to April next year, and I am being forced to seek an alternate provider now as I can neither log in or reset my password in order to use the fucking junk app.
PIA isn’t fit for purpose, and they appear to have taken everyone for granted. Even Linus Tech Tips won’t touch them anymore.
