hi, would you know why any iptv i use and your will only work if I have my vpn turned on? if my vpn is off then iptv will not work or load my isp is xfinity
Your service is probably blocking your ip address or a range of ip’s.
Your ISP is blocking. The public IP is impacted. If you turn your modem off for a while say 15 minutes, and provided you don’t pay extra for a static IP, it will assign you a new public IP address. That should make it work well again for a while until your ISP sniffs out your new IP again.
VPN is for a reason, that is why you have one ![]()
Your ISP is blocking the servers…
How’s this related to tivimate??? Your issues are about the IPTV providers you select and/or your ISP.
You’re in the wrong sub for your issues
Been using iptvfluid. com , never got worried about having vpn, maybe because they are not that known
Need more updates to get active service
not a tivimate topic… go /r/somewhere else
Xfinity like spectrum blocks everything.
Had an issue where my provider was security blocking
Some iptvs get blocked by internet providers. Not all do tho. Either stick with using the VPN, or try another iptv and see if it will work without. Most offer free trials so it would be really easy to know if it works or not without paying for a new sub
Login to your router and turn off any nanny settings.
Some IPTV servers only work with VPN on when major sports matches take place.
But some IPTV services offer VPN already built in.
Ask for a free trial on a match day and compare your service with the new service and you will find out.
I have Comcast as well u/JohnnyLive28
Use different DNS servers. Tell your router to hand out custom DNS addresses. I use Comcast but my router uses other public DNS servers (like google). My service works with VPN on and off.
Could also be xfinity blocking, they have done that regionally. Do a quick test with your phone hotspot. If it connects ok on the hotspot without vpn it’s probably Comcast. At that point you’ll have to run the vpn or switch ISPs.
Not one, not two…but three question marks.
You mad lad.
i’ve had spectrum for over 7 years and never blocked my iptv streams
hey which iptv service comes with vpn built in?
