What the title says pretty much. I live in Turkey. I’ve been using Bitdefender VPN almost a year. A bit more with shared usage from my friend before I owned it myself. I could always instantly connect on any device. But since last 3-4 months, I’m having problem connecting on my PC, only on PC.
I did everything that a generic customer representative would ask of me. Fresh windows install, driver reset, network reset commands on command prompt, opening routes and firewall rules everywhere with suggested port numbers, changed to different protocols manually, to no avail.
On the other hand, my phone still instantly connects to VPN via Bitdefender VPN app. Only change I made is to select wireguard protocol manually. Germany server always works from Turkey and the most stable one with the least ping.
All I want is to resolve this on my PC, since my phone can connect with no settings required pretty much says it’s not ISP related, and I can also say I have no possible security software that would conflict with VPN.
I have 15 days left on my annual sub, a renewal depends on if you solve this or not.
I tried to send data before, but your representative gave me all sorts of wrong directions and wrong links to upload my data and I ended fed up and forgo doing anything about it.
And about no connection, it happens like this, I select germany, I press the power button thingie to connect, and then it says connected, secure connection, but IP status is stuck on “exposed”. This happens with wireguard. Can’t connect to any website or anything. And when I enable openvpn protocol with scramble, it says connected, btw it takes a lot of time in “connecting” phase in either protocol and other protocols don’t even work, like a minute at least, it says “your vpn connection is cut”, then tries again, 1 more minute. IP status goes private, and then when I try to access any site, this time it says your internet access is blocked. And sometimes, voila, I one-shot the connection without changing anything, just keep changing protocols until one sticks. And I’m scared to power off my computer because I won’t be able to connect again.
I typed all this, just for you to be able to work a solution around this mess.
Edit: when I wait 2-3 minutes before trying to connect, it connects. Means some initialization process is going wrong in the background. u/bitdefender people might want to look into that.
