Hulu Recording issue RUNUNK13 error
Getting many failed recordings on Hulu after the first couple record okay.
visible.mmt shows screen stuck on “Error playing video
We encountered an error playing this video. Please try restarting the video or select something else to watch.
Hulu Error Code: RUNUNK13”
Is anyone else seeing this for multiple queued Hulu recordings?
On Playon .103.
hi everyone, i found a pretty decent fix for the RUNUNK13 Error! setting the quality to DATA SAVER instead of BEST POSSIBLE has consistently fixed this issue for me and I am no longer getting the RUNUNK13 error on the hulu website.
Playon is messing up on Hulu recordings. It’s failing on recording many episodes. Even when visible.mmt shows an episode is playing, Playon does not even start recording at all. Have tried several different shows, stopping and starting Playon. No help.
I looked it up: “What is RUNUNK13 on Hulu desktop?Hulu error code RUNUNK13 appears when you try to play a movie or show on Hulu, and the player is unable to complete the request. Corrupt data on your end, network connectivity issues, or problems with Hulu’s servers can cause the error.”
Haven’t tried recording Hulu in a while. I know there were things going on this past week causing login issues for me - I was watching, not recording. Channels merging? Disney. Forget who else. Maybe Comcast?
Hopefully, it will settle down. Maybe it’s not a Playon issue.
This issue appears resolved with Playon version .105.
It’s not resolved. I believe it’s a Hulu via web browser problem and not really PlayOn. I have had certain titles that it’s taken literal days to as much as a week to record - I just keep retrying until the one time it doesn’t error. There are several recommendation to dump cache (browser) to fix it. As a result I have tried dumping \ProgramData\MediaMall\Cef\cache but it rarely makes any difference.
I have also read that switching to Firefox (from Chrome) resolves the issue, but we don’t have that option in PlayOn.
