When I search for how to use split tunneling on iOS I get this info.
To disable NordVPN for specific apps on an iPhone, you can use the split tunneling feature:
Open the NordVPN app and navigate to Settings
Select Trusted apps
Choose the apps to exclude from the secure VPN connection
However I think this is either incorrect or outdated. When I go into the app and look at settings there is no “Trusted apps” section and nothing about split tunneling.
There are some apps on my phone that simply do not work with NordVPN enabled such as Ticketmaster. So I’m looking for a way to have the vpn either automatically turn off when i use said apps or some sort of filter.
Edit: I don’t know why this is marked as solved now. Nothing has been solved.
