How to use Norton VPN on PS4
So I’m trying to get a VPN set up on my PS4 (mainly for US Netflix) and I already have Norton VPN on my PC so I’m using that rather than buying another one. I’ve tried bridging a connection through my PC into my PS4 using an ethernet cable, but when the VPN is turned on the PS4 fails to connect to the Internet (thinks its connected but loads forever).
Has anyone else tried this/know if it’s possible?
Yea I just wanna use HBO and shit ps4 won’t let me download it for canada now what? Buy an Xbox?
I’m pretty sure to get American Netflix you only have to change the DNS server numbers, I could be wrong though
It might not work but im still gonna say.When i was using my phone internet as a wifi it when had vpn if i know right.
Yeah I was debating this as an option, but VPNs slow your Internet down with each device connected to a router (and we’re already having issues with that :joy:). Essentially short term VPN connections are what I’m looking for.
Upvoted though as it’s definitely a solution :+1:
No luck for me trying this, I think Netflix have altered it so you can’t do this anymore.
I could be using old DNS codes though :thinking:
I’ll give that a look. Cheers!
