I am desperate to buy a Hulu subscription because it is the only streaming service I have found that has almost all of my favourite shows on it. I was wondering if anyone has been successful in buying a subscription using a VPN (I have Nord) or if it’s just not possible due to having a Canadian credit card. Thanks!
Not your exact circumstance: I bought it in Italy using Express VPN through the Apple App Store (linked to my US credit card) and it works fine on my laptops and phone as long as my VPN is up. So perhaps using your App Store will work
I believe so. I’m from the US but I used a vpn while abroad to watch Hulu. I’m not sure if the credit card will be an issue though
Only a few VPNs can bypass the hulu VPN ban. Most will not work and result in users receiving the anonymous proxy tool error message.use residential vpn ip will help you unblock any streaming content(netflix,hbo,hulu,disney). recommend widevpn, suport wireguard, unblock any content. $9.99/yearly. only residential vpn ip work .
hmm okay, I don’t have a US credit card but perhaps if i load my iTunes account with enough funds it might work. Thanks for the suggestion!!
