Apparently this has been going on straining about 7-13 months now. None of the employees I work with No one has connected to the employee Wi-Fi. Not even our manager does no one knows how to connect to it? I’m just curious at this point because it will always ask for a Identity, password and a domain? No one here knows what that means.
me and all my coworkers just connect to the main wifi. the password is usually on the wifi router and it’s usually in the office somewhere.
Lmao for once I’m agreeing with lolwill. You don’t. Been there for over 3 years and I’ve tried everything I could to connect to that damn WiFi and it doesn’t work. I don’t understand why we have employee WiFi that us employees can’t use.
its usually just for DM access
I believe it’s just for DM’s and higher, i help a store that is in the middle of the mountains and does not get service i had my dm sign me in so I could have service so family could get ahold of me easily if needed
No one is our store not even the SM knows the employee wifi
Don’t. I use the free wifi + VPN and it gives me access to all I need to do, just turn it off when ya go home
Its for DMs. I was lucky enough my dm gave me the login for ours lol
You need a dg email which only dms and above have
I asked the store manager. He didn’t know (to be fair, he was new and no one knew). I emailed…portal? I forget what it’d called. They told me to ask SM. I told them he didn’t know. They told me to contact the DM. That’s the point the juice was no longer worth the squeeze.
I got lucky, had a since fired key give me the deets for our store employee WiFi, and use a good VPN
You don’t. You want internet access? Use the 5G that should come with your phone plan.
This. Blew my mind that the people working in the store I’m currently working didn’t know that was a thing before I transferred.
What vpn works? I tried mullvad and the iCloud relay VPN and neither would connect to anything on the DG public WiFi.
