Hello everyone,
As all express vpn mod users (including me) saw that it stopped working in the last week, i started using this vpn and highly recommended it for people as an alternative until a new express vpn mod is released, its similar to it and easy to use and i began loving it
Without futher notice here is hola vpn download link premium unlocked.
Ill update the post with virus scan when i get home , enjoy everyone!
Hola in the past has used your own connection as a VPN connection for other people, even when you’re not using it.
ExpressVPN still works. Download ExpressVPN from the playstore and download appcloner from mobilism. Clone ExpressVPN by going into the privacy options and cjoosing change android ID. This will allow you to sign up for another free trial with the clone app once the trial is over clone it again. This is also much safer than downloading a modded one since you get the origi nal.
1 flag on VT: https://www.virustotal.com/gui/file/ba38ff124c1944f931b300d138ed4479e87afd71566a5bfd053f9636cc76c2af/detection
Never use P2P VPN. Hola VPN is P2P and one other VPN but I forgot it’s name. If someone makes a terrible crime and your IP and bandwidth was used as VPN connection by someone else then you are pretty much ready for jail.
Hey u/androidgamemods, Please ensure that your post follows the required post format for this sub-reddit to avoid it being removed. If you’re sharing an app, please ensure that you include a VirusTotal Report with it.
Unlimited free trials for ExpressVPN for android:
Install express vpn from play store.
Install appcloner apk.
Disable internet to app cloner app via any firewall app or you can disconnect from 2G/3G/4G/5G/wifi while using app cloner app.(otherwise it will ask you to update the app, if that’s the case clear data.)
Open app cloner. Select express vpn.
Scroll down to privacy options.
Click on “Change android ID”.
Select “Random”.
Go back. Click on apply.
Wait the cloning process, install from the pop-up. You may uninstall the one installed from Playstore. Use the cloned app as your vpn.
This way you have the latest app with no malware.
Tried this a week back. Doesn’t work for me
Yea i just checked the playstore original unmodded one and it shows this flag too
one flag is quite clearly a false positive.
have to do this every 7 days ?
Just did it right now. Make sure youre doing it right. Also saw somewhere that it doesnt work on Android 11
Yeah more than likely, just thought I’d post the link as I downloaded it to test myself.
thanks.
do you know any other vpn with free trial that offers data, instead of days ?
express offers 7 days trial, i want something that get 1 gb for example for trial.
FYI 7 days is a win over your 1gb example. you can consume that tiny bit with 1 or 2 movies.
You are right but i use one for web and another one for doqnloading things.
