Help with VPN and Android Casting
I want to cast my android device to my television, which I know how to do but it requires to be on the same network as the television…
So I thought I would use split tunneling on android for just my browser/app, when I do that it still disconnects me from the cast cause apparently I changed networks how to fix this?
Have you tried turning on Allow LAN Connections?
Try to disable split tunneling, activate lan connections and turn off the option to block connections without vpn. Thats the only way i can access my home network with vpn connected,
what is that? sorry I do not know
Exactly this. Tried yesterday and worked like a charm.
It’s a known issue that’s even reported on their GitHub.
They just either don’t have the ability to fix it or they just don’t care. They haven’t even acknowledged the problem on GitHub and it’s been there for nearly two years now.
Go to settings and turn on LAN Connections. This should allow you to cast on your network
