I have been using the VPN sharing in Astrill for a very long time and it used to work very well with my Quest 2 VR.
But lately I can’t manage to make it work anymore, I always get this error in the Astrill logs: “Failed to enable ICS on VPN interface. VPN sharing will not work.”
I think I tried everything I know from my side:
ICS is running in Windows services
Network discovery is enabled for both public and private networks
Reinstalled Astrill
Run Astrill as Admin
Tried on both Win 10 and Win 11: none working
Tried with a different internet connection, still no joy.
I contacted Astrill support about this issue but they blamed it on Windows and they got away with that excuse.
At this point I guess i won’t be able to connect my VR to the internet anymore, kind of hopeless :-/
If anyone has encountered this problem and managed to fix it somehow it would be very much appreciated if you let me know.
              astrill is.fucking dogshit. the mods here got paid to promote it just like they did for express which is also shit. do not give astrill any more money
              Not sure about Astrill, but I sideloaded V2Ray onto my Quest 2 and use Wannaflix VPN to still be able to use the Internet.
              JFC
Search the group before posting things about whether a VPN is down.
              Do you really think they’re paying us?
              Thanks for the suggestion! I didn’t know about Wannaflix VPN, I’ll check it out and hopefully I will be able to use again my quest 2
              The VPN itself isn’t down. In general it works well for me, just the sharing feature within Astrill isn’t working anymore as it used to do, sadly.
              Give it a try! Use Side Quest (search on Google) to load V2Ray onto the quest. Then you can just use the URL provided by your Wannaflix account and add that to a new subscription on V2Ray. Your available servers will be loaded in and then you can just select one and connect.
              Trying right now
 I went to the GitHub page of V2Ray and I saw there are several APK versions. which one did you download?
              Ah that’s a pity. Honestly it’s hard to find a decent VPN alternative so I have been using Astrill for 12+ years. Which VPN are you currently using?
              Totally disagree. Been using it for 3 years and it’s a very smooth experience for me.
              I’m afraid I don’t remember. Just try any one which works with Android and it should be fine on the Quest 2. Feel free to keep commenting or PM if there are any problems.
              No worries, thanks much for helping out
