Egypt VPNs restrictions and how I got around them
Hello everyone,
Remote employer and wanted to write this out for however it might help in the future,
I current use Open or Wireguard as my personal virtual private network and I also need to log in to my company’s virtual private network as well to get into my work stuff. I knew Egypt had strict limitations on using those so I took a week off from work and try my luck if I was able to get it running, which I did. I found that both VPNs platforms (OpenVPN or Wireguard) are blocked, so to get around it, I would share my Google Fi hotspot (which already has a proxy built into the connection) to my GL iNet and would run OpenVPN on top of that connection to access my company’s internal network, a bit slow but overrall solid connection and I would recommend.
Also I read online that there were limitations in Jordan on VPNs but I saw no restrictions and could run all of my private networks without any issues, if there’s any questions about working from either country I’m glad to help.
gif
You do know their 56k dialup is unfiltered
Take one those up addresses.
Do you know if saudi has these restrictions ? I plan to travel there and want to set up a vpn from home I will also visit egypt. Also what kind of device do you use back at home ? I hear brume 2 is good?
I used Mullvad obfuscation and that works, although very slow (since Egypt’s internet is painfully slow as-is).
It seemed to me like they had some restrictions on Wireguard but no restrictions on OpenVPN, so I would stick to that. And any GL iNet works, the model doesn’t matter that much so the Brume 2 is a good option, but I do carry 2 routers as a backup.
That would have been useful but I need to connect to my home’s IP so that wouldn’t have been an option, great to know for anyone else looking to do this.
