So i live in canada and i used mullvad to torrent games and such and liked it a lot, but i was wondering if it worked well with netflix.
I would like to access US and Japan netlflix, maybe Uk. if it dosen’t work please share the options that do.
Thanks
Looking for the best Netflix VPN? Check out the wiki! https://www.reddit.com/r/NetflixViaVPN/wiki/index
Nope. Doesn’t work with any streaming. I would suggest checking out the wiki and reading about TorGuard.
No Mullvad doesn’t work with streaming and they don’t care about it imo, You will need another vpn like Windscribe, express vpn etc.
Netflix has a strict vpn blocking so only a few vpns can overcome it. Find a vpn that Netflix doesn’t block. I personally use Nordvpn that offers a good price, decent speeds and works with Netflix
I did not Mullvad Vpn for that reason, and if that’s your main goal with a vpn, you should probably go with another vpn.
However, I did try to unlock Netlfix with Mullvad, and I did not have any issues. I used uk, us and brazil servers.
Don’t wont to be kicked of this sub but Windscribe would be best for needs or Express vpn
