Hi all,
I have a Synology DS1520+ that has all my Docker containers running.
Those Docker containers are connected to a VPN network that’s set up with a (Nord) VPN container. I want to reverse proxy those containers because Synology’s reverse proxy is a hassle if you reset migrate it. This same setup did work on my Synology reverse proxy setup though…
Nginx Proxy Manager is running correctly and the containers and network is up running too. I’ve tried different methods via various posts throughout various forums and guides but I’m kinda new to this and my set up is kinda different from the general setups I come accross.
I’ve gotten it to work on one occasion but that’s only if I connect all my containers to my Macvlan (done via Portainer) but then the VPN would be of no use (and I don’t want that).
I use Cloudflare for my DNS and that seems to be fine too.
I’ve tried to connect Nginx to my VPN network so they can all be on the same network but that doesn’t work.
I get either a 504 error or a 523 gateway error…
I’ve connected Nginx to my router (via Macvlan) because ports 80 and 443 are occupied by Synology itself.
I don’t have a config file set up because I don’t understand it well or find it on YouTube channels explaining that.
Here’s my Nginx Proxy docker compose with ombi as an example container I want to reverse proxy. Please let me know if I’m missing a big clue or made a noob mistake. I’m also not great at networking and I believe that’s the mainl issue and reason why I made this post. Thank you all in advance:
version: '3'
services:
nginxproxy:
image: 'jc21/nginx-proxy-manager:latest'
container_name: NPM
restart: always
depends_on:
- db
ports:
# These ports are in format <host-port>:<container-port>
- '888:80' # Public HTTP Port
- '4444:443' # Public HTTPS Port
- '81:81' # Admin Web Port
# Add any other Stream port you want to expose
# - '21:21' # FTP
environment:
# Mysql/Maria connection parameters:
DB_MYSQL_HOST: "db"
DB_MYSQL_PORT: 3306
DB_MYSQL_USER: "npm"
DB_MYSQL_PASSWORD: "npm"
DB_MYSQL_NAME: "npm"
# Uncomment this if IPv6 is not enabled on your host
DISABLE_IPV6: 'true'
volumes:
- /volume1/docker/nginxproxymanager/data:/data
- /volume1/docker/nginxproxymanager/letsencrypt:/etc/letsencrypt
- /volume1/docker/nginxproxymanager/themepark:/etc/cont-init.d/99-themepark
- /var/run/docker.sock:/tmp/docker.sock:ro
stdin_open: true
tty: true
networks:
net:
ipv4_address: 192.168.x.x
#OR networks:
vpn_default
db:
image: 'jc21/mariadb-aria:latest'
container_name: NPM-DB
restart: always
environment:
MYSQL_ROOT_PASSWORD: "npm"
MYSQL_DATABASE: "npm"
MYSQL_USER: "npm"
MARIADB_AUTO_UPGRADE: 1
volumes:
- /volume1/docker/nginxproxymanager/mysql:/var/lib/mysql
stdin_open: true
tty: true
networks:
vpn_default
ombi:
image: lscr.io/linuxserver/ombi:latest
container_name: Ombi
environment:
- PUID=1026
- PGID=100
- TZ=Europe/xxx
#- BASE_URL=/ombi #optional
volumes:
- /volume1/docker/ombi/config:/config
ports:
- 3579:3579
restart: unless-stopped
stdin_open: true
tty: true
networks:
vpn_default
