Can't use Netflix with letsVPN
Hello guys,
My problem is in title. I’m using letsvpn it is nice and smooth with anything else. But I’m suspecting letsvpn somehow to be blocked with netflix.
It doesn’t matter what web browser I am using (i tried opera, chrome, edge, firefox) on my computer or my phone, as well as netflix app, I can’t connect to my netflix account.
Either it says that my password is wrong, and if i want to recover it it says “sorry a problem appear, try again later”…
I contacted Netflix support, they send me email to change my password, but even after I changed the password, no change, still says my password is wrong…
Otherwise I simply can’t enter the website, the page loaded is white with written “not available”
Anyone already has this issue ?
The problem is Netflix actively blocks access over VPN. Only thing you can do is try different VPN servers, find one that works. I use Astrill, not Lets, but some servers work with Netflix and others get detected and blocked. Gotta experiment until you find the right one
Iv heard it doesnt work for letsvpn, but keep trying different servers and see if you get lucky.
Btw, telling you the password is wrong is a common error you get when using a vpn.
mine works though.
Try other locations? i used singapore because… im from singapore
It’s does work for me, try different locations
It’s Netflix, that’s why I gave it up living here. It’s honestly not worth the hassle of trying to find which server works and allows decent streaming speeds when I can torrent on any VPN connection, and even without it if I don’t care about privacy because I’m in China beeyatsh, what’re you gonna do?
I’m at Shanghai atm and use astrill and can confirm that it works great.
Okay tonight I’ll try any simple location available on letsvpn and see if one is working.
Thanks for the advice
Thanks for this clarification ! It is definitely vpn related then !!! So stupid they are restricting vpn with netflix… I’ll certainly cancel my netflix subscription in the near future…
I’ll try Singapore tonight then !
Astrill is sooo expensive tho… i prefer the small hassle of not being able to use netflix (especially with torrent) than to pay 30usd per month for a vpn…
Update : Singapore (and many other locations )didn’t work for me…
So weird
But when company pays i dont care :sweat_smile:
