Can't turn on custom protocols
I am currently on the macos sequoia beta preview and I don’t see the “Some system software may require your attention before it can be used” section. Connecting works, and I see the VPN configuration, but I’m unable to switch to different protocols like TCP.
Based on feedback from another Sequoia user, try Settings → General → Login & Extentions → Network Extension.
It is in settings under General > Login Items & Extensions > Network Extensions.
You should really update this and change that video that pops up once the app is installed on Mac.
I’ve been searching the internet for the answer to this - thank you!
This worked! you should update the information on your app & website
Hey guys, you have to update the support page and the app pop-up!
