Can't figure out how to install NordVPN
I just made the switch over to CachyOS from OpenSUSE and am having a hard time installing NordVPN. Following the instructions on the Nord site will throw an error
❯ sh <(curl -sSf https://downloads.nordcdn.com/apps/linux/install.sh)
fish: Invalid redirection target:
I tried using wget and got the same error
Found out it should be in the AUR named nordvpn.bin, however I can’t seem get to get it to pull up.
I tried paru -S nordvpn-bin, which does find it and asks if I want to install but then just displays the config and doesn’t do anything past that.
❯ paru -S nordvpn-bin
:: Resolving dependencies...
:: Calculating conflicts...
:: Calculating inner conflicts...
Aur (1) Old Version New Version Make Only
aur/nordvpn-bin 3.19.2-1 No
:: Proceed to review? [Y/n]: y
:: Downloading PKGBUILDs...
PKGBUILDs up to date
/home/sapien/.cache/paru/clone/nordvpn-bin/PKGBUILD
# Maintainer: Cabel <mxzcabel at proton dot me>
# Contributor: metiis <aur at metiis dot com>
# Contributor: Julio Gutierrez <bubuntux at gmail dot com>
# Contributor: Martoko <mbastholm at gmail dot com>
pkgname=nordvpn-bin
pkgver=3.19.2
pkgrel=1
pkgdesc="NordVPN CLI tool for Linux"
arch=('x86_64' 'i686' 'armv7h' 'aarch64' 'armeabi')
url="https://nordvpn.com/download/linux/"
license=('GPL3')
depends=('libxml2')
provides=('nordvpn')
conflicts=('openvpn-nordvpn')
install=nordvpn-bin.install
source_x86_64=("https://repo.nordvpn.com/deb/nordvpn/debian/pool/main/n/nordvpn/nordvpn_${pkgver//_/-}_amd64.>
source_i686=("https://repo.nordvpn.com/deb/nordvpn/debian/pool/main/n/nordvpn/nordvpn_${pkgver//_/-}_i386.deb>
source_armv7h=("https://repo.nordvpn.com/deb/nordvpn/debian/pool/main/n/nordvpn/nordvpn_${pkgver//_/-}_armhf.>
source_aarch64=("https://repo.nordvpn.com/deb/nordvpn/debian/pool/main/n/nordvpn/nordvpn_${pkgver//_/-}_arm64>
source_armeabi=("https://repo.nordvpn.com/deb/nordvpn/debian/pool/main/n/nordvpn/nordvpn_${pkgver//_/-}_armel>
sha256sums_x86_64=('57c48cf7543e0c97a5ac4122a5c9f0237040be9badefd535dd4f74f2eead8ccc')
sha256sums_i686=('ad5c637b37143bbc1f3adbd85641c6e7dc22f46c51b53e33303901f3c0d0b578')
sha256sums_armv7h=('9d034f0410c52d2f91d8c2ef5b015bbe578176d9bf6db54d75558dbe873a337b')
sha256sums_aarch64=('bf4be8c0aada97142808d430334d5e270b44baf1a755c65f6ad40bc0bafc3a36')
sha256sums_armeabi=('1f6ee868ba4d20ffcb069c080c44881479b76f0101905e39894c4cff81166b1d')
package() {
bsdtar -O -xf *.deb data.tar.gz | bsdtar -C "${pkgdir}" -xJf -
mv "${pkgdir}/usr/sbin/nordvpnd" "${pkgdir}/usr/bin"
rm -r "${pkgdir}/etc/init.d"
rm -r "${pkgdir}/usr/sbin"
echo "g nordvpn - -" | install -Dm644 /dev/stdin "${pkgdir}/usr/lib/sysusers.d/${pkgname}.conf"
/home/sapien/.cache/paru/clone/nordvpn-bin/nordvpn-bin.install
post_install() {
echo ':: In order to enable nordvpn you have to start the following service:'
echo ' sudo systemctl enable --now nordvpnd'
echo ':: You have to add yourself to the nordvpn group:'
echo " sudo gpasswd -a USERNAME nordvpn"
echo ':: You then have to restart for the group to be created:'
echo " reboot"
# Add logic to avoid interposing with sqlite library if it already exists
for lib in /usr/lib/nordvpn/*.so ; do
if [[ -f $lib ]] ; then
if [[ ! -f "/usr/lib/$(printf '%s' $lib | cut -d '/' -f 5)" ]] ; then
ln -s $lib /usr/lib/
fi
fi
done
post_upgrade() {
if [[ $(readlink -- /usr/lib/$(printf '%s' $lib | cut -d '/' -f 5)) == $lib ]] ; then
unlink /usr/lib/$(printf '%s' $lib | cut -d '/' -f 5)
fi
fi
fi
done
pre_install() {
if [ -d /var/lib/nordvpn/data/ ]; then
chattr -i /var/lib/nordvpn/data/*
fi
pre_upgrade() {
pre_remove() {
fi
fi
done
(END)
Thanks in advance! I’m sure it’s just something simple that I’m missing like usual.
Yes when you download via pacman it will give all that text. Think you press escape or q and and say yes to get it to finish.
Then run these to make sure you run these…
systemctl enable systemd-resolved
systemctl start systemd-resolved
When done
sudo gpasswd -a $USER nordvpn
Then
sudo systemctl enable nordvpnd
Finally
reboot
Now you should see nordvpn icon…on kde i have it on the bottom right.
There should be doco on nordvpn’s page on how to login
Why Nord VPN ? Take Mullvad or Proton VPN :+1:
You need to click “Q” if the review is coming
Thank you! All I had to do was press the Q key. I knew it was something simple.
I got a free year key from a friend a few months back so working my way through that before I consider another one. I already use Protonmail so I more then likely will just go with that one.
Also (potentially not recommended), if you want to skip this every time, you can edit the file /etc/paru.conf and add SkipReview under the [option] section.
Note that this is potentially unsafe since you’re expected to read through the PKGBUILD to make sure they’re safe.
I was thinking about doing that (saw I could elsewhere) but figured I’m not Linux savvy enough and could use the reminder that I’m doing something that requires review haha.
