Hi, I’ve been trying for the better part of 2 days to connect to the VPN, but I always get the ‘BF-CBC’ error with all sorts of errors. I tried regenerating new configuration files, changing VPN Server locations, tried editing the cipher multiple times. I set up a new VM with different network settings but that didn’t work. I even tried asking GPT with the full errors but even it couldn’t come up with the right solution.
I have absolutely no clue what I’m missing here and why it just won’t work.
Any suggestions or ideas would be more than welcomed
In your Linux terminal, make the script executable with chmod +x . If you downloaded the script to your Downloads folder, this would be chmod +x ~/Downloads/thm-troubleshoot.
Run the script by typing sudo followed by the path to the script into your terminal and pressing enter. If the script is in your downloads, it will be the following command: sudo ~/Downloads/thm-troubleshoot.
The script will instruct you on how to proceed from there.
Contact support, they are the ones who sent me those steps and after going trough them and changing my file from a normal one to a “VIP” one it worked.
If you are a paid user try and regenerate a VIP file and try to connect with it.
