Can i use another vpn with 1.1.1.1
i live in Turkey and i cant use discord and roblox because its banned in some reasons and i want to use them but the 1.1.1.1 with warp makes it really slow and if i only use 1.1.1.1 its fast but i cant enter any of the banned apps or games
If the VPN client doesn’t offer custom DNS, you can download the OpenVPN or WireGuard config and then edit it to use 1.1.1.1 for resolver.
Why though? If you’re using a VPN then nothing should be blocked anyway regardless of the DNS (unless you use a filtering DNS, such as 1.1.1.2 or 1.1.1.3), and in case of 1.1.1.1, it doesn’t suppose to block anything outside specific sites due to court order.
You can extract the WireGuard config from Warp with wcgf and then chain it with other WireGuard config, but all you get will be increased latency.
