Can I extend my VPN membership from 4 to 9 years?
Currently, there is a deal on stack social where you get 5 years of AdGuard VPN for 35€, and I’ve wanted to ask if it is possible to add another 5 years to my current membership which still has 4 years of service remaining.
I hope you guys understand what I’m trying to ask
EDIT: It worked. After I purchased, I received a 15% off code which is valid for one month. Because I won’t use it, you guys can have it: bygqncj
I believe it will stack up. I have mine shown as 6 years (1+5). The 5 years was also purchased on stacksocial.
Good call. Mine expires in two years but that’s a good price for 5 years. I may have to do the same.
You can use code ADSDSAVE for $10 more off. At least in the US.
Wow, thx for the info, i just purchased it, and stack it right away,
you can do that by choosing ‘Bind License’ in ‘License’ menu in the Account Management page
mine originally expired on April 2025, now it become April 2030. Good deal.
Use the code TAKE20 for another 7 dollar discount
:thinking::thinking: can I stack it twice and get 10 years?
Thanks for this. Just extended mine as well. Since AdGuard VPN licenses also includes AdGuard DNS paid version, I’m so happy!
I have the same question, someone can confirm that it will stack up?
What are your experiences with this VPN? I already own other, but I’ve always been thinking about this one to merge it with Adguard app on android and be able to use both at the same time
Can I buy 2 lots from stack social and stack them?
It this working with adguard dns?
Thanks. Just tried it, it will stack up
Thanks a lot, it worked for me!
Yep that is a major value adder because they essentially give you 5 separate hosted adguard servers. We use adguard home on OPNsense with this as the upstream DNS as I prefer to filter on the local instance as I have convenient control using home assistant and local caching but I have servers setup there for my parents and siblings using the fantastic HaGeZi lists and it’s been hands off but effective. I have “better” VPN’s but if you are not trying to be a kingpin it’s great, they have a local server using M247 just like Mulvad and has worked great with my IPTV services.
what is the difference of Adguard and Adguard DNS?
I’ve just tried it. It works and will stack up
Same I also just stacked mine. Went from 2 years to 7 years.
I felt that this vpn is slow when compared to others like Surfshark and Nord. But then again we can also use AdGuard along with vpn here
Yes. The vpn deal also includes the DNS personal plan
You can run a private DNS servers and you can block trackers, ads etc. systemwide
