Bought turkey netflix giftcards from eneba but they are not working. Happening to someone else?
Hello! If you need a VPN, check out the guide here!
I’ve bought a bunch from them and so far these have always worked.
Had the same issue a few days ago. Bought a code on Eneba, which didn’t work. Got a new code as a replacement, which didn’t work either.
Requested a refund and purchased a working code elsewhere.
Bought 2 gift cards last week on Turgame… worked as expected.
Applied not under VPN.
They explain in descripción, these will not work on accounts that have pay with a card before.
You need a new account if the rule is not acomplished
Send me 1 and I’ll check it ![]()
The seller trustworthy or high rating ?
Happened to me a few weeks ago.
Wait 24 hours and try with a different IP / VPN . It gave me error the first day and after a few days and a different vpn they worked
I opened a request to eneba they told me to wait 3-5 days. After all I asked them to close the ticket cause they worked.
There’s 2 ways to use the codes. One is the netflix.blablabla/tr/redeem
And the other one is when finishing your account and selecting wich suscription you want, you decide to pay with a gift card.
Try both, just in case. My account was made via vpn and gift cards were activated with different VPN but from Turkey too
i can also provide gift cards if you need
Will I need some sort of phone number to complete setup of N?
I buy always from eneba never had a problem redeeming. I don’t even use a vpn
When you bought them, did you use vpn? Because I didn’t use VPN when buying them but I used vpn when trying to use the code
It’s working my codes now
Can’t create account with turgame as it asks for verification code. Public phone numbers from sites like online sim.io doesn’t work. How did u verify?
It worked tho. Turned off vpn and then worked
It worked after I turned off vpn lol
How much are yours for turkey?
No, I only use a VPN when redeeming the gift cards on the Netflix website.
Gamivo.com @ seller: “Top Notch Keys”
